The goal is to array an object along a curve using 2 reference points, so the start of the next instance is the end of the previous object.
Example: array a fix sized fence frames over a fence line.
This is how I do this step by step:
Measure the Distance (S1-S2) of the object or fixed distance you want to use.
Orient the source object point S1 to the curve start point T1.
For S2 put in the distance (S1-S2) for the next step. With this fix distance find the intersection point on the curve T2.
In the Orient function set the option Copy and continue with S1=T2 and repeat the previous steps until the end of the curve is reached.
Can someone help to script this command?
If Rhino developers read this: An adapted ArrayOnCrv function for this could benefit from the record history option so you can adjust the curve afterwards.
