Query Materials doesn't seem to be working
Hello , the query Revit materials is not working. I created this script months ago and had no problem with it until only recently, I guess when I updated it.
As you can see, according to “Create Material”, the name is already in use, however when I use Query Material, it doesn’t find anything in the existing revit file. Please note that the Text component has the name the I’m looking for.
Hi @attheeast18
for me the Query Materials component seems to be working (but I am not 100% sure of what you are doing with your script :sweat_smile:).
I had a similar issue with the latest Rhino.Inside update, but that was because with the latest update I also had to install the latest hotfix for Revit 2022 (hotfix 2022.1 or higher). By the way, in your first image, it seems that you do not have the latest update from Rhino.Inside, I do not know if that is also a problem.
Thnx man. I should update. I suspected if that was the cause because it worked long ago. It’s been a while since i updated. Anyway what I was doing with the script was automatically converting blocks into revit families and creating a material for it.
