Sorry! The Convert Material component reported an error
Convert Material.gh (3.3 KB)
Sorry! The Convert Material component reported an error. May I ask what causes it?
Thanks for reporting, we’ll take a look. What version of Revit are you using?
Revit2023.1.10
Thanks, I’m not seeing this, but might be behind on a Revit update. Can you post a screen shot of the detailed info in the About dialog
okay,i’ll got it…
Is this in a particular project? Does this happen if you create a new Revit Project and try again?
Yes, again, in revit2020 and revit2023, there will be an error using the convert material component…
However, with the exception of the rhinoinsiderevit WIP version, I’ve had no problems using this component…
Yes in a particular project or happens in a new project? I haven’t been able to repeat this, it seems project specific. Can you provide a small sample of the project where I repeat this?
Hi @sijia,
This problem should be fixed now on the current daily build, it will be soon released on the RC as well.
  • Great, I can use it now, thank you
Hi! japhy, first of all thank you very much for your help. But it has been fixed in the latest WIP and now I can use it normally.
