QuadRemesher face errors
I was playing around with this. It’s amazing. Got a small but for certain settings. If I change some of the settings I get really good results. Not sure if it’s worth reporting but I’ve attached the file. The settings are the ones from the screenshot.
QuadRemesh.3dm (904.9 KB)
Best,
If you uncheck the Detect Hard Edges, what happens? I get something better.
I believe this is what @Trav fixed earlier today. There is something that Detect Hard that can mess things up.
I also played with Use Surfaces faces Off at the same times and it allowed the mesh to get much simpler. The nearest row of shapes were done without Surfaces Faces. Trying to see how few I could get way with.
Looks like we are all going to be learning about this together.
Same issue. If I change some of the settings I get really good results. It is working really well, I just wanted to point out the issue with the specific settings.
yeah objects without hard edges should have the box unchecked. I just added a fix this morning that will resolve this in the next public build.
Fantastic job Trav!! :+1::+1::+1:
Hello everyone,
any idea how to fix this issue here?
this is using quadRemesh, i also tried much higher numbers for target count and still the same problem!
you might want to post the actual file or a portion of it. also, explain a bit more what you are actually trying to do, maybe also post the initial geometry before quadremeshing.
hexagonal pattern.3dm (3.3 MB)
here is the file. I want to have a clean quad mesh so i can structurally analyse it.
@encephalon
Hi -
QuadRemesh works better when the object has thickness.
You have a repetitive pattern and I extracted one of the panels and extruded it to give it thickness.
You can then explode the resulting mesh and only keep the front face and perhaps copy that for all panels that you need.
For some types of analysis, a regular trimesh can also be used…
the quadRemesh looks really good, my concern would by when tesselating the panels, subds wont match the next panel!
