Python: SplitCurve with ponts
Hello
I am having some issues with the SplitCurve command in Rhino.
When I try to split a curve using a point as parameter (I have checked with IsPointOnCurve and the point is part of the curve) I have unexpected results.
I have a list of points and I am using one of them to split a curve created with AddInterpCurve.
What am I doing wrong?
Can I use the point’s coordinates directly in the SplitCurve or do I need to convert it to parameter first? If so, how do I do it?
Thank you so much,
Ricardo
Is the curve closed? You can’t split a closed curve at one point, you need to supply two. And yes, you do need to convert the point coordinates to a parameter for splitting, you cannot pass a 3D point directly. Use CurveClosestPoint to get the parameter at the 3D point.
Otherwise, perhaps you can post the curve and the parameter/point you want to split at for testing.
–Mitch
thanks yet again. the use of CurveClosestPoint does work. the curve was not periodic so it got sorted out quite easily.
Ricardo
