Help with script, split curves with picked points?
any idea why this isn’t working? thank you
or a better alternative to select some curves, then pick points to split them at?
Option Explicit
'Script written by <insert name>
'Script copyrighted by <insert company name>
'Script version Friday, October 01, 2010 12:50:16 PM
Call SplitCrvsWithPts()
Sub SplitCrvsWithPts()
	Dim arrCurve,arrIdPoints,arrPoints,str,el
	arrCurve = rhino.getobjects("select curves to split",,, True)
	If Rhino.IsCurve(arrCurve) Then
		Rhino.Print "The object is a curve."
		arrPoints = rhino.getPoints(,, "put Points on curves")
		rhino.enableRedraw vbfalse
		str = ""
		For Each el In arrcurve
			str = str & "selid " & el & " "
		Next
		arrIdPoints = rhino.addpoints(arrpoints)
		rhino.command("_split " & str & " enter selpt _enter")
		rhino.deleteObjects arrIdPoints
		rhino.enableredraw vbtrue
	End If
	End Sub
Hi @kleerkoat,
Here is a simple Python version:
def split_curve_at_points():
    curve_id = rs.GetObject("Select curve to split", rs.filter.curve)
    if not curve_id: return
    points = []
    while True:
        point = rs.GetPointOnCurve(curve_id)
        if point:
            points.append(point)
        else:
            break
    if len(points) == 0: return
    parameters = []
    for point in points:
        t = rs.CurveClosestPoint(curve_id, point)
        parameters.append(t)
    pieces = rs.SplitCurve(curve_id, parameters)
    if pieces:
        rs.DeleteObject(curve_id)
if __name__ == "__main__":
– Dale
try changing these two lines:
to:
arrCurve = rhino.getobjects("select curves to split", 4,, True)
If Not isnull(arrCurve) Then
thanks Dale, Jarek got me on track
nailed it! thank you!
i still can’t get it to work on multi curves
now your isn’t working
what’s the error/problem ?
it only selects one curve, i’d like to pick multiple crvs and then place poims on them. instead of doing one my one.
ty
this works fine over here:
Option Explicit
	arrCurve = rhino.getobjects("Curves to split?", 4,, True)
		If isnull(arrPoints) Then Exit Sub
		Rhino.enableRedraw False
		str = ""
		Next
		rhino.enableredraw True
	End If
End Sub
