Python rs.command("-_print")
Is there a way to use rs.command("-_print") in python and not having to select preview before accually printing the document?
I see three options in ths dialog:
Go, Setup, Preview.
What does Go stand for? (nothing hapens when pressing it except the function ends)
Also is there a way to use -_print to set name and destination of the printed document?
Hope this makes sence.
Best regards
-_Print _Go _Enter would try printing into your current print setup.
rs.Command("_-Print " + " _Enter " + newFilename + " _Enter", true);`
should work if you want to print into a new file with “newFilename” being the variable.
Hi, Thanks for the replys.
I get nor of the two options to work.
Seams like I can’t input name or path to where the file is suppose to be placed.
Shouldn’t the path+filename be possible to add under -_print -> _setup -> _destination menu?
More suggestions are welcome.
Best regards
@stevebaer is it only me who can’t get this to work, or is it not suppose to be possible to print pdf directly from rs.command("-_print")
Thanks in advance
Printing a Rhino document should work like described above. But since you’re printing a pdf you could try using System.Diagnostics.Process.
Something like:
from System.Diagnostics import Process, ProcessStartInfo
p = Process( );
psi = ProcessStartInfo( )
psi.CreateNoWindow = True
psi.Verb = "print"
filename = r"myfile.pdf"
psi.FileName = filename
p.StartInfo = psi
p.Start( )
Hi Alain,
Thanks for the help!
That bit of code is a bit to much for me to take in =)
Is that python language?
I tried it out in the python editor (where the rest of my code is) but it only gave me:
“The system cannot find the file specified”
The help is much appreciated!
Best regards
I noticed in How to print a pdf from python? that using
_-Print _Setup _Destination _Printer “Microsoft Print to PDF” _Enter _Enter _Go
gives a new promt to:
Save file name (browse):
But Changeing to:
_-Print _Setup _Destination _Printer “Rhino PDF” _Enter _Enter _Go
Gives no option, instead I get to “save Print output As” dialog.
I would like to have it as the “Microsoft Print to PDF” option but with “Rhino PDF” printer.
This way I don’t have to write a filename in the dialog box and pressing Enter.
Is this understandable?
Best regards
I would recommend using the following technique for saving with Rhino PDF
Thanks @stevebaer!
I knew I had read this somewhere.
Sorry for the double posts
Best regrads
Steve, is there a similar method to capture the layout pages to PNGs? This is awesome, by the way!
Hey Brad,
Capturing to images is handled by the ViewCapture.CaptureToBitmap functions
https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Display_ViewCapture_CaptureToBitmap.htm
https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Display_ViewCapture_CaptureToBitmap_1.htm
Perfect! Thanks, Steve.
One interesting little thing… I have a display conduit that draws some geometry. I also have some clipping planes that apply to 2 of 5 DetailViewPorts in a layout page. Using the CaptureToBitmap method, the clipping planes are respected. However, they are not respected for the PDF export method.
Hey Brad,
Please start a new thread with details of the bug. It sounds like there is something to track down here. Thanks!
