Python/Rhinoscriptsyntax - some kind of funky unicode error?
I am getting an error in the rs.CheckListBox() method, and it seems to be some kind of weird unicode problem.
Here is the test script:
#!/usr/bin/env python
# -*- coding: utf-8 -*-
names=["Default","0","Existant"]
#names=["Default","0","Existant","à démolir"]
name_list=[(name,False) for name in names]
print name_list
msg="Pick an item"
CLB=rs.CheckListBox(name_list,msg)
for item in CLB:
   if item[1]: print "Chosen: {}".format(item[0])
Which runs OK. Now uncomment line #7 (the one that has the list with 2 accented characters) and run it again.
It errors out with
"Message: Unable to translate bytes [E0] at index 0 from specified code page to Unicode."
Now these are standard accented characters, notably typed with à = Alt+0224 and é = Alt+0233 . Normally they are accepted as long as I have the
at the top of the script. So what is going on here?
Note that the print name_list line also spits out this:
[('Default', False), ('0', False), ('Existant', False), (u'\xe0 d\xe9molir', False)]
Is this some sort of bug, or am I doing something wrong?
Thanks, --Mitch
You aren’t doing anything wrong. This is an outstanding bug that I’m still trying to figure out how to fix. The CheckListBox function itself doesn’t know how to deal with strings.
Ahh… too bad. :frowning_face:
Hi Steve,
I’ve encountered an issue that might be related. So I just drop it here:
# coding=utf-8
diam = 'Ø'
print diam
print str(diam) #the str() function throws an error
Thanks
-Willem
Had that problem too and fixed it by using the “unicode()” conversion instead of “str()” in a customized CheckListBox function:
import Rhino
def CheckListBox(items, message=None, title=None):
    checkstates = [item[1] for item in items]
    itemstrs = [unicode(item[0]) for item in items]
    newcheckstates = Rhino.UI.Dialogs.ShowCheckListBox(title, message, itemstrs, checkstates)
    if newcheckstates:
        rc = zip(itemstrs, newcheckstates)
        return rc
    return scriptcontext.errorhandler()
#names=["Default","0","Existant"]
print name_list
msg="Pick an item"
CLB=CheckListBox(name_list,msg)
for item in CLB:
https://mcneel.myjetbrains.com/youtrack/issue/RH-38621
There is also this:
diam = 'Ø'
print diam
print "{}".format(diam) #format function seems to convert automatically
–Mitch
str() in rs.CheckListBox() will throw an error on that formatted string anyways
Yes, you would still have to modify the CheckListBox definition in userinterface.py either with unicode() or format(). But, of course, until the error is officially fixed, a custom definition in the script will make it work everywhere.
–Mitch
Thanks Jess, I’ll look into using that technique.
Thanks Jess!
Really usefull pointers.
-Willem
All thanks go to @dale !
