Bug: PropertyListBox
Hi RMA,
the rs.PropertyListBox i.e. Rhino.UI.Dialogs.ShowPropertyListBox does not like utf-8 characters like Ä Ö Ü and so on. Here a python example:
# -*- coding: utf-8 -*-
import Rhino
def test():
    keys = ["key1","key2"]
    values = ["one","über"]
    results = rs.PropertyListBox(keys, values, "Edit Values")
    if results:
        print results
test()
Is there a way to work around the problem?
Thanks,
Jess
Hi Jess,
Apparently the problem lies with the str() method in rs.PropertyListBox.
You can directly call Rhino.UI.Dialogs.ShowPropertyListBox() passingf your own list of stings like so:
import Rhino
def test():
    results = Rhino.UI.Dialogs.ShowPropertyListBox('title', "Edit Values", keys, values)
    if results:
        print results
test()
HTH
-Willem
Hi Willem,
great thanks! I too ran into that str() conversion problem some time ago…
Best,
Jess
Hi @dale @stevebaer
I ran into more problems with Rhino.UI.Dialogs.ShowPropertyListBox:
  1. An empty string value “” is represented as blank " " in the dialog. This is not a big problem since I can take care of that myself. However, I think it should be fixed.
  2. If I confirm the dialog with the Right Mouse Button the attached script runs to the end, not showing any more dialogs. Is this by design? How can I avoid that?
Check out the attached sample.
PropertyListBoxBug.py (883 Bytes)
Thanks,
Jess
I haven’t been able to do this at all. If I click on the OK button with the right mouse button, nothing happens (which is what I would expect.)
Hi Steve,
you’ll have to click RMB outside of the dialog.
Per this conversation, I’ve added these YouTrack items;
https://mcneel.myjetbrains.com/youtrack/issue/RH-38621
The reason the form closes when you right-click off the form is because the form is display as semi-model, which means the dialog is modal but view command works (e,g. pan, zoom, rotate view). Thus, there isn’t anything that can be done about the behavior.
– Dale
RH-38621 is fixed in the latest Service Release Candidate
