layers = rs.LayerNames()
if layers:
items = [(layer, rs.IsLayerOn(layer)) for layer in layers]
results = rs.CheckListBox(items, "Turn layers on/off", "Layers")
if results:
for layer, state in results: rs.LayerVisible(layer, state)
How can i change “layers” with my own desired fields and how can i store the checked items in my file?
the documentation says rs.CheckListBox requires a list of tuples as ‘items’ argument. the results will again be a list of tuples.
there are several ways to store the results in your file, (e.g. rs.SetDocumentData, sticky values). How do you expect to use the data after storing it?
cheers,
Tim
items = [('val1', True), ('Val2', False)]
results = rs.CheckListBox(items, "Show my check options", "Layers")
if results:
# print results
for result in results:
print result[0], result[1]
Thank you so much
my first problem is solved
i mean i want to store checked items in my file (when im checked one box next time i run the script it showed the checked
In your case you need to put where you have your True and False values the actual value of the sticky.
Not behind a pc right now but if you click on the checkbox and it returns a value, set the sticky to that value.
I’m actually not quite sure what you are trying to achieve but here is an example of how you could use a sticky to store a layer state once. After you run the script the second time, it will read the previously stored state and set the checkboxes accordingly.
import scriptcontext as sc
if sc.sticky.has_key("layerstate"):
items = sc.sticky["layerstate"]
else:
if layers:
items = []
for layer in layers:
is_on = rs.IsLayerOn(layer)
items.append((layer, is_on))
sc.sticky["layerstate"] = items
if results:
if rs.IsLayer(layer):
