Python, Not Returning Result Outside Function
#SelectSurfaceCornerGrips
srf = rs.GetSurfaceObject('Select a surface for corner point display', preselect=True)
if srf:
    srf = srf [0]
srfPtCount = rs.SurfacePointCount(srf)
uCount = srfPtCount [0]
vCount = srfPtCount [1]
srfPtCount = uCount*vCount
#Report the total number of points, Yes/No option?
def PrintSurfacePointCount():
    print "Point Count: " + (str(srfPtCount))
    print "U Count: " + str(uCount)
    print "V Count: " + str(vCount)
def SelectSurfaceCornerGrips(srf):
    #u is a row index, with a total of 'v' points, Corners at (u0, u1, u2, u3)
    u1index = uCount-1 # Zero based, final point of first row
    u3index = srfPtCount-1 #Zero based, final point of the surface
    rs.EnableObjectGrips(srf)
    u0 = rs.SelectObjectGrip(srf, 0)
    u3 = rs.SelectObjectGrip(srf, u3index)
    u1 = rs.SelectObjectGrip(srf, vCount-1)
    u2 = rs.SelectObjectGrip(srf, srfPtCount-vCount)
    p0 = rs.ObjectGripLocation(srf, 0)
    p1 = rs.ObjectGripLocation(srf, u3index)
    p2 = rs.ObjectGripLocation(srf, vCount-1)
    p3 = rs.ObjectGripLocation(srf, srfPtCount-vCount)
    points = (p0, p1, p2, p3)
    return points
print points
if points:
    rs.AddPoints(points)
#Option for Creating Points VS Selecting the Points
#Will it work for 3 sided surfaces?
I’m trying to clean up some of my early code trials and learning by trying functions. I thought I was using return properly, to return the result of some arguments in my function SelectSurfaceCornerGrips function to use later on. In return points and then print points, it becomes clear I haven’t used it correctly. It worked before anyway as a line by line piece of code, so I’ve kind of taken a step backwards by adding the functions, for now.
Any help appreciated!
should read:
points = SelectSurfaceCornerGrips(srf)
You do return points, but you weren’t assigning the result to any variable, so they went straight to bit heaven.
Thank you Nathan!
Makes sense, merely invoking the function wasn’t actually returning the data anywhere.
Baby steps continue…
