Hi, I’m trying to create a simple python script inside a grasshopper python component that exports fbx (I’ve ecountered the same problem also when exporting normal objs too) that gives me an error and tells me Failed to save as /Users/jorgemuyo/Desktop/GRASSHOPPER_EXPERIMENTATION/OBJ_TEST/combined_animation.fbx.
The file writing plug-in failed.
When exporting as obj or fbx from rhino itself I have no problem, only when doing it through python. Does anybody knows why this could be happening. I’m currently using a mcbook pro m2
Here is the scrip I’m using:
import os
import Rhino
from System import Array
def combine_fbx_files(folder_path):
# Check if the specified folder exists
if not os.path.exists(folder_path):
print(f"Folder ‘{folder_path}’ does not exist.")
return
# Get a list of all FBX files in the specified folder
fbx_files = [f for f in os.listdir(folder_path) if f.endswith('.fbx')]
if not fbx_files:
print("No FBX files found in the specified folder.")
return
# Sort the files based on the numeric part in their names (test_1, test_2, ...)
def extract_number(filename):
try:
return int(''.join(filter(str.isdigit, filename)))
except ValueError:
return float('inf')
fbx_files.sort(key=extract_number)
# Initialize Rhino document
rhino_doc = Rhino.RhinoDoc.ActiveDoc
if rhino_doc is None:
print("No active Rhino document.")
return
# List to hold all object ids imported from FBX files
all_object_ids = []
try:
# Import each FBX file and collect object ids
for fbx_file in fbx_files:
fbx_file_path = os.path.join(folder_path, fbx_file)
result = rhino_doc.Import(fbx_file_path)
if result:
print(f"Imported {fbx_file_path}")
# Get object ids of newly imported objects
new_objects = rhino_doc.Objects.FindByObjectType(Rhino.DocObjects.ObjectType.AnyObject)
if new_objects:
all_object_ids.extend([obj.Id for obj in new_objects])
else:
print(f"Failed to import {fbx_file_path}")
# Check if any objects were imported
if not all_object_ids:
print("No objects imported.")
return
# Create a list to store selected object references
selected_object_refs = []
# Get selected objects
selected_objects = rhino_doc.Objects.GetSelectedObjects(False, False)
for obj in selected_objects:
selected_object_refs.append(Rhino.DocObjects.ObjRef(obj.Id))
# Export selected objects to a single FBX file
output_path = os.path.join(folder_path, "combined_animation.fbx")
options = Rhino.FileIO.FileWriteOptions()
options.SelectedObjects = Array[Rhino.DocObjects.ObjRef](selected_object_refs)
options.WriteSelectedObjectsOnly = True
options.WriteGeometryOnly = False # Include animation data
options.WriteFileUnitsAndTolerances = False # Use defaults
success = rhino_doc.WriteFile(output_path, options)
if success:
print(f"Exported combined animation to {output_path}")
else:
print("Failed to export combined animation")
except Exception as ex:
print(f"An error occurred: {ex}")
finally:
# Clean up: delete all imported objects from the document
if all_object_ids:
rhino_doc.Objects.Delete(all_object_ids, True)
rhino_doc.Views.Redraw()
Example usage:
if name == “main”:
folder_path = “/Users/jorgemuyo/Desktop/GRASSHOPPER_EXPERIMENTATION/OBJ_TEST”
