Python Command - Import created module: expected an indent block
I’m having an issue with creating a command; once I import a module that I have worked on, it throws an expected indent block message; while not having the import, lets the command work without any issue.
def RunCommand( is_interactive ):
    print "test"
RunCommand(True)
import AcmNumber
    print "test"
RunCommand(True)
It likely means that the error happens in AcmNumber.
Try opening the AcmNumber module, run it and see the line number.
You are correct, it was because I didn’t set up the "is __name__ == __"main":" inside of AcmNumber properly; after doing so, everything runs well.
