Hi all,
I have never added a python script to a command before. After hours of trying I don’t think I would figure this out by myself. The script I am adding is the Array Between from @Gijs. According to this page “Creating Rhino commands using the Python script editor” am I suppose to add @Gijs script the line below “def RunCommand( is_interactive ):”?
I got the script to work as I did this (see script as follows) but when I save, exit and restart Rhino and run the command. Rhino gave me this Python Script Error. I couldn’t figure our where I did wrong.
----------------------copy and paste to Rhino Python Editor-----------------------------
import Rhino
from System.Drawing import Color
import scriptcontext as sc
__commandname__ = "arraybetween"
def ArrayBetween():
def OnDynamicDraw(sender, e):
i=optBasePoint[0]
pts=[]
count=optInt.CurrentValue
if i==0:#center
basept.X = center.X
basept.Y = center.Y
if i==1:#lowerleft
basept.X = center.X-width/2
basept.Y = center.Y-depth/2
if i==2:#upperleft
basept.Y = center.Y+depth/2
if i==3:#lowerright
basept.X = center.X+width/2
if i==4:#upperright
vec = e.CurrentPoint - basept
gp.SetBasePoint(basept, False)
line = Rhino.Geometry.Line(basept, e.CurrentPoint)
curve=line.ToNurbsCurve()
params=curve.DivideByCount(count-1,True)
for param in params:
pts.append(line.PointAt(param))
length = vec.Length
dist=length/(count-1)
vec.Unitize()
for i in range(1,count):
translate = vec * i * dist
xf = Rhino.Geometry.Transform.Translation(translate)
newobj=obj.Duplicate()
newobj.Transform(xf)
if obj.ObjectType==Rhino.DocObjects.ObjectType.Curve:
e.Display.DrawCurve(newobj, Color.LightCyan, 2)
if obj.ObjectType==Rhino.DocObjects.ObjectType.Brep:
e.Display.DrawBrepWires(newobj, Color.LightCyan)
e.Display.DrawLine(line, Color.Blue, 2)
def getPoint():
while True:
result = gp.Get()
if result == Rhino.Input.GetResult.Point:
line = Rhino.Geometry.Line(center, gp.Point())
pts=[]
vec = gp.Point() - basept
length = vec.Length
vec.Unitize()
sc.doc.Objects.AddCurve(newobj)
sc.doc.Objects.AddBrep(newobj)
sc.doc.Views.Redraw()
elif result == Rhino.Input.GetResult.Option:
optionindex = gp.Option().CurrentListOptionIndex
optBasePoint[0]=optionindex
getPoint()
break
docobj = rs.GetObject("select object to array", 28)
if not docobj: return
if rs.IsCurve(docobj):
obj=rs.coercecurve(docobj)
if rs.IsBrep(docobj):
obj=rs.coercebrep(docobj)
if not obj:
return
plane=Rhino.Geometry.Plane.WorldXY
bb=obj.GetBoundingBox(plane)
if bb==None:
print "can't calculate boundingbox"
return
center = bb.Center
basept = bb.Center
minimum = bb.Min
maximum = bb.Max
center.Z=minimum.Z
width = maximum.X-minimum.X
depth = maximum.Y-minimum.Y
gp=Rhino.Input.Custom.GetPoint()
gp.SetCommandPrompt("point to array to / distance")
optInt=Rhino.Input.Custom.OptionInteger(3,3,999)
gp.AddOptionInteger("Count",optInt)
basepoints=["center", "lower_left","upper_left","lower_right","upper_right"]
gp.AddOptionList("basepoint", basepoints, 0)
optBasePoint=[0]#equal to index 0 of basepoints option
gp.DynamicDraw += OnDynamicDraw
getPoint()
if( __name__ == "__main__" ):
ArrayBetween()
