Pull Curve on a surface -> Incomplete Curve
Hello All,
How to fix this? (the pulled curve lacks of a segment)
Usually I try to explode the curve or split the surface, but I would like to have something more efficient.
Test 1.gh (9.8 KB)
Thank you!
Maybe you can use the Project component as an alternative, although the result is not exactly the same :sweat_smile:
I think it is because the Pull Curve component pulls only once. If I split your curve in half and get the part not pulled, then the Pull component works as you are expecting.
I get the same behavior with circles and a flat surface.
If you use this it will work with Pull Curve.
Pull curve on surface.gh (8.7 KB)
Thank you for you reply Fernando.
In the meantime I “fix” the problem by flipping the curve direction, pull the starting curve and the flipped one in two separate commands. But your solution works way better. Thank you!
