davrave
(Davrave)
November 8, 2019, 2:38pm
1
Afternoon All, appreciate if you have the time to help with the below problem, which I’m sure is rather basic.
I am well and truly stuck with manipulating data in a tree. The tree has three branches, (
. Data to populate the branches is read from a spreadsheet using TT toolbox.
Branch 1, {4}: Points to draw line from
Branch 2, {7}; Points to draw line to
Branch 3, {10}; Type of line (there are 5 types) to draw between the nodes from and to.
Problem : How do I draw lines between the nodes, and be able to distinguish between their line type?
thanks in advance
David
Asking questions and getting answers is what this forum is all about. Although people are generally very helpful, there are things you can do to improve your chances of getting good and quick answers. Below you will find some suggestions, but don’t think of them as rules and especially don’t think of them as guarantees.
1. Choose a descriptive title for your post
Don’t title your question Help! or I have a problem or Deadline tonight!, but actually describe the problem you are having.
2. Be s…
Internalize and post the data in that panel as a GH file. Explain “Type of line”?
We don’t need or want TT toolbox or the spreadsheet, just the data please. Do you expect people to re-create your example by hand?
Hint: Explode Tree
davrave
(Davrave)
November 14, 2019, 2:29pm
3
Apologies, as you can see I am a novice.
Attached is the Grasshopper file. To simplify the problem, I would like to be able to draw lines between “Points to” and “Points from” with Line type 1 or 2 (1 = Column, 2 = Beam). For now, a simple cube is drawn, but the lines simply join the nodes, and there is no way to distinguish between columns and beams.
This way, I can use Tekla plugin to model a building frame later.
STICK MODEL_forum.gh (5.6 KB)
Jakinta
(Jasmin Cubic)
November 14, 2019, 2:40pm
4
how about testing dot product with Z-vector?
Sorry, i reread your post, the structure will be more complicated then cube…
Maybe Member Index is what you are looking for…
Is this what you have in mind? Obviously there is a problem resolving the intersections…
STICK_MODEL_2019Nov14a.gh (19.0 KB)
davrave
(Davrave)
November 14, 2019, 3:26pm
6
Chaps,
This is excellent, and I believe we are so very close. Tekla plugin simply requires lines to be plugged into their components, dont actually need to model any extrusions in Rhino. So simply differentiate between columns and beams with their lines, and then insert lines into the component - any thoughts?
Screenshot to illustrate what I am trying to ask:
Really? As before: Explode Tree
Jakinta
(Jasmin Cubic)
November 14, 2019, 3:50pm
8
Just a note: You can always sort your set and rename paths so you dont get confused which branch goes where.
davrave
(Davrave)
November 14, 2019, 4:10pm
9
Both,
Thankyou very much for solving my problem - much appreciated. I’d have never got there on my own
Regards
David
