Properties panel not showing all sub options
I’m trying to apply texture mapping onto some objects but the option to enter the texture mapping menu under the properties side panel suddenly disappeared as shown below there are only three options under properties, and I can’t find the option to bring it back. I tried using the surface mapping command manually but the box to actually edit the texture also doesn’t show, any solutions?
Screenshot 2024-05-24 064339
Hi Brian - please make sure these plug-ins are enabled and loaded-
If that does not sort it out, please run the SystemInfo command in Rhino and copy/paste the reasults here.
Are you using the built in Rhino renderer?
HI Pascal, it seems that there was most likely a problem with another plugin I had just installed. The problem resolved itself after I removed said plugin. Thanks for the info!
