I’m trying to project some arabic text onto a surface i have made, however, nothing I do seems to be working, I have attached both the rhino and grasshopper file for reference. and i will also attach a screenshot what it should be similar too. I would appreciate any help I can get on this, thank you!
I don’t know why this ellipsoid shape fascinates me… I did two more variations of the shape, analyzing surface curvature in all four cases contained in one GH file.
Original from your post (circular cyan group)
V.Two from my earlier post (white group)
V.3 using 20 PFrames and Loft(gray group - worst, too many PFrames?)
V.Sweep adapts a method I posted 3 days ago in your other thread(orange group, best)
Again, V.Sweep is best (orange group, on the left in the curvature analysis image)
P.S. I found a mistake in version V.3(gray group) where changing the PFrames count did not update Range. Unfortunately, reducing the count doesn’t help, it’s still the worst version. Replaced GH file version ‘b’ with version ‘c’.
Hi Quan, although this is closer to what i am looking for, it’s not exactly the same, I want the sides (which is where i am having the most issue) to go around so it’s more on the x axis (if you are considering that the shape is the plane). Thank you!
this is great! i tried to make it the that i had done because majority of the building needs to be parametric and I figured the way i had done it would be simplest
Even if you don’t see differences (and I do), because of how they are constructed, it’s just impossible for your ‘Original’ to be as fair as ‘V.Sweep’.
P.S. The R7 Rhino file I posted has one layer locked by accident. Unlock it.
In Rhino, use ‘Analyze | Surface | Curvature Analysis’ or ‘Analyze | Surface | Zebra’ to see how fair each version is.
This bothered me - I knew the model wasn’t fully parametric with a ‘nudge’ (fudge) slider.
It took awhile but was simple to fix, once I fully understood the geometry. This image shows the ellipse and its center point/plane (in green) created by the cyan group:
Considering how your original shape was created, it was remarkably fair. But experience designing boat hulls told me that there are too many “offset” values to be truly fair.
By the way, the ‘Radius 2’ slider in the cyan group is replaced by two ‘Radius 2’ sliders in the orange group, one for the outer rail and one for the inner rail.
