Problem with nautilus distribution
Hello every one,
I would like to ask two questions, according to nautilus plugin. In my work, i want to create groups of cubes with uniformly distribution of points, which will be a voronoi’s centers. I occured two problems and i cant solve it.
  1. I want to create cubes with specific porosity (for example 30%). When i am doing it by ‘cubic distribution’ and set for example 500 points i get 62% porosity, but when i increase number of point even a little for example to 510 i get over 70% porosity (i cant set anything between). What is the problem? Can i solve it in some way?
    First example:
    points1
Porosity:
porosity
Second example:
points2
Porosity:
porosity2
  1. I want to create cubes with hexagonal distibution of points, and i have to set the box with dimension: 30x30x30 [mm]. When i pick hexagonal from ‘populate box uniformly’ Rhino crushes and i cant do anything (even when i was waiting 1 hour)? Do you know what the problem is?
Here is my .gh file:
Nautilus_problem.gh (14.9 KB)
Do you see any option of help? If yes i will be very grateful!
Hello
the “maximal number of points” is a sort of security in order to have not too much points because many point will lead to long calculation time of the Voronoi component. And I didn’t put a limit for the hexagonal component so you have 38958 points !!! This is a bug. I must put a limit. It will be in next version.
And as we deal with similar polygon I must have put Voronoi cells outputs, so it will be no necessary to use Voronoi component for so “simple” configuration.
So I advise you to use the step size that is usable. Let says between 3 and 4. And put a Dam in order to control
Mesh intersection from Dendro could also be used. It is a bit faster.
Nautilus_problem_LD.gh (15.7 KB)
And you could also use Lattice tools there are quite better at this type of job.
https://www.food4rhino.com/en/app/intralattice
It is not maintained but worked well.
Thank you very much! One more question…is there anyway to check number of points inside box, if i only change the step size?
And i think that is not possible to get structures with porosities 30 and 70% exactly, am i right?
In order to have a point count you can use
I think it is not true but your way of calculating porosity is not perfect.
Porosity could be estimated if there are a great number of cells or using a unit cell.
For example with a cube unit cell porosity will be a function of the ratio between rod radius and cell size.
So it could be better you use a unit cell (simple for cube as it is a Box) and change the radius to calculate the porosity. You will end up with a sort of S function. Porosity as a function of radius.
Oh Now i am understand. That is game changing answer to be honest. If you don’t mind, because i see that you are perfect teacher :D. You said before, that i dont need to use voronoi block, when i am doing uniform distribution. What is the easiest way to connect the points and get rid of the voronoi function? I know there is a lot of options, but which one is the easiest?
In order to have a cell you could the Voronoi Cell component
This last component is not in the current release. But it is just used to explode grouped objects
Nautilus_problem_LD_2.gh (8.5 KB)
Okey, but what if i want for example use cubic distribution of points…and connect them with lines? Is this possible?
Same as you did
Nautilus_problem_LD_2.gh (14.0 KB)
I am really sorry, maybe i was not precise. I want to create some distribution of points, for example this cubic or hexagonal one. When i do it, i am getting some number of points and now i want to just connect this points with each other, nothing more. I just want to create this boxes, by connecting points, not by using voronoi rules.
You could use Proximity3D component.
Okey! Thank you for your time and for a lot of help!
