Hi, I’m having issues trying to flow an array of square along a curved surface. The surface is formed by drawing a curve with points and then extruding it. When I try to flowalongsrf, the squares are not evenly spaced on my surface… Any idea why and how to fix this? Thanks.
Hi @pascal, I’m having a similar problem where I’m using UnrollSrfUV to unroll my curved surface and then FlowAlongSrf to “move” my squares on the curved surface. If I toggle “rigid” to “yes” the spacing isn’t kept but with “rigid” no, it is… any idea how I could keep them rigid and spaced properly?
Actually, I found another one of your discussion on a similar topic and fixed my problem using the solutions you had proposed. Just in case others have the same issue, here’s what @pascal had proposed and worked for me:
ShrinkTrimmedSrf (turns out my surface was already trimmed but I tried just in case)
Then I “Rebuild” and more than doubled the U & V
UnrollSrfUV (with Explode = no, not sure what it does)
Hi Nic - It is fixed in the Windows V6 ‘WIP’ as far as I know. If that fix is not in the most recent WIP then it should appear soon- I’ll double check when I get back to the office, but I am pretty sure I tested a fix for this the other day, if we are talking about the same thing,
Ah, sorry I thought you meant the mac WIP as I also tested there and in the “normal” windows version. Thanks in any case for checking, your support is very appreciated.
