Problem transferring from Grasshopper to Rhino
Why does my model disappear or become incomplete when I transfer it from Grasshopper to rhinoceros, even when using the Bake function? Could it be because the object is too heavy?
Hi Océane -
Without the .gh file, it’s impossible to say. Make sure to internalize data from Rhino and from plug-ins.
Can you open the file?
Océane Conceição (final mesmo).gh (34.4 KB)
Yes, but you didn’t internalize data…
Uploading: Oceane Conceição (este).3dm…
Océane Oliveira da Conceição.gh (59.5 KB)
And Now??
Nope.
If I understand the issue that you are trying to report, all we need from you is one single component that internalizes all geometry that you want to bake to the Rhino document. Everything else is irrelevant.
ok, thank you :slight_smile:
I baked the geometries I wanted to transfer to Rhino. I’m showing how it turned out with this image. I didn’t internalize, so that might be the reason.
I’ll try!!! (sorry for my English)
Hi Océane -
Internalizing is only something you do to make it possible for other users to correctly open your Grasshopper file. It doesn’t fix anything on your end.
I have no idea if that picture shows that things went fine or not…
