Problem Solved
Thanks, problem solved.
Hi Mike,
I can help you out with this if you are still looking for someone.
Hey Adam,
I found someone, but please send me your profile and I’d like to consider
you for future projects.
Best,
Mike
Hi Mike,
Sounds like you found someone for this project. For future reference, I could definitely assist you with this type of work. Here’s an example of a similar project I worked on:
http://www.danedleson.com/#!berkeley-manifold-wall/ob888
Dan,
Thank you so much for responding. Since I’m new to CNC machining, I will
definitely need some help with designs while I’m starting out.
Actually, would you be interested in making a file for a simple farm table
leg? I’ve got a 4th axis lathe on my Laguna Smartshop II to make the cuts.
Best,
Mike
Network with us at FB: Barndog Mill, IG: @barndogmill, Twitter:
@mikegennaro, Linked In: Mike or Jen Gennaro, jengennaro.com
Mike,
I’d love to help. Is there a number and a good time to call you in the next
day or two so we can go over some logistics?
Best,
Dan
I looked over your amazing portfolio, and you are clearly overqualified to
do this bit of work, lol. I’m going to be going through CNC training for
the next two days. I’ll let you know if I need help after that. Now I’ve
got your contact info for future projects.
Best,
Mike
Sounds good. Always happy to contribute.
