Problem referencing point from grasshopper in rhino
Im having trouble from the referenced points in rhino, while i set on point or on multiple or curve they are being referencing but only in grasshopper preview, if i make a change in rhino the change doesnt appear in grasshopper. any solution?
Hi Raphael,
Is there an actual point in Rhino or are you picking points on curve?
A screenshot or file would help us understand your workflow better.
What is the desired workflow?
im still on tutorials, here screenshots
I’m seeing this as well, i requires a Canvas Refresh to update. I’ll post a youtrack number shortly.
appreciated. thank you!
