I have a model in Revit, which I exported as DWG with ACIS solids. I have imported it into Rhino without problem, and now I want to use select part of the model in Grasshopper.
I used the Brep “Set multiple breps”, I have no problems with the Walls and Floors. But with the windows it keeps displaying the message “A referenced brep could not be found in the Rhino document”.
I cannot figurate out what’s the problem. Has anyone got this problem before?
Btw, I know about Rhino.inside Revit. But it only works with Rhino 7, so at the moment I have to do it on this way.
Here I attach the DWG file of the building. Building Model.dwg (998.2 KB)
I’m not trying to import families, but a full model. The windows are simple glaze without frame (I have simplified everything for the test).
I have modified my first message and upload the DWG file of the model, if you can have a look.
Sorry I’m not at a computer right now. If you select the window element in the imported model in rhino, what does the rhino commandline say you have selected?
It’s usually a block. Explode the block then select the sub element
