I am having problems with Rhino 7 printing command. It takes a lot of time to respond to commands, like chancging scale, and mostly it seems not to be working as in previous versions, very slow.
I just saw that the same file printed to PDF in Rhino 5 and then Rhino 7 had 46Mb compared to 500Kb, so the problem is there somewhere, on the output specification. I have not tweaked any of these settings, so it is the as deliverd setting that is causing this huge file size.
Me again, it´s the resolution setting. It comes as standard as 600 dpi, which looks to be over what´s needed here. Anyone with a link to material discussing the correct resolution values to be used to print engineering plans, A0 size?
One more update. My partner in the office has also Rhino 7.0, and did not tweak any settings on Rhino Print to PDF, so our settings and options were exactly the same, and his file came out at 330 Kb against 46Mb of mine.
So this is specific to my system it seems. I will try to send you the file and system info.
Hi, I am printing as Vector, and that is the default setting, which was the same on my friend´s system.
The printing is with Rhino PDF.
On My Rhino 5, I am printing the same portion of my model, also as Vector, and the file comes out at 500k, instead of 46M.
The very menus are not working well, any option I want to change, like, switch betwenn rhino PDF and Microsoft Print to PDF, causes the system to hang, not responding for maybe 30 or 40 seconds.
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 16Gb)
Primary display and OpenGL: NVIDIA GeForce GTX 1650 (NVidia) Memory: 4GB, Driver date: 11-20-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 457.49
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-20-2020
Driver Version: 27.21.14.5749
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\Flamingo nXt 5.0 (fd53f8c4-546d-47d1-8820-e66c97645a97)\5.5.18018.1000\5.5\Legacy\Flamingo.Legacy.dll "Flamingo nXt Legacy File Reader " 5.5.18018.1000
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\Flamingo nXt 5.0 (fd53f8c4-546d-47d1-8820-e66c97645a97)\5.5.18353.6521\5.5\Flamingo.nXt.rhp “Flamingo nXt 5.5” 5.5.18353.6521
I found where things were going wrong and solved the issue. I was printing from an old Rhino 5 file, without saving it to Rhino 7 first, because I did not want to commit to the new version in case things did not work well. This has happened before when Rhino 6 was not maintaining format for dimensions and texts and drawings produced in Rhino 5 were not printing well in Rhino 6. Of course I vould have saved a working copy and tired from there, which is what I did later, and things started working well. So it appears the problem was printing from a Rhino 5 file. When it was saved to a Rhino 7 file it all started working normally.
