Print width in properties window
Hi!
We have used Corel Draw to import drawings to laser cutter. Now we want to skip Corel and import drawings directly from Rhino to the cutter. Print width has to be 0.001. When I use print width 0.001, properties window shows only 0.00.
How can I get there one more decimal to see that width is correct without inserting it again? I mean I want it to show me one more decimal in the properties window. Unit tolerance in options is 0.001.
Henri
The display looks to have been hard coded in Rhino to 2 decimal places (bug)… But the actual print width is what you set it to…
I filed this as a bug, there are a couple of related issues I found also :
http://mcneel.myjetbrains.com/youtrack/issue/RH-29308
–Mitch
Thanks Mitch!
Now I know it is in progress…
Henri
