Having an issue when printing a scaled view of my model.
In the images below you can see I want to print a view of the model on an A1 page @ 1:200 scale. I created a scaled rectangle in the model which represents an A1 page @ 1:1 to give an idea of what rhino should theoretically be printing.
As you can see, the rhino’s preview of the print doesn’t match up with the rectangle and instead shows a much smaller area. You can see this when I inserted the exported image into an illustrator file which is sized to A1. I’ve checked all my units and model scales both in Rhino and in Illustrator and everything checks out, but for some reason, rhino is messing up the size of the paper when printing.
Any help would be appreciated ![]()
1.200 campus plan.ai (1.8 MB)
Wrong paper size.3dm (10.0 MB)
- Edit:
In Illustrator the size of the rhino print is that of an A3. The same issue occurs when trying to print at A2 & A0 but A4 works fine. Effectively it seems stuck at a maximum paper size of A3
*Edit 2:
Using ‘export selected’ instead of ‘print’ doesn’t change anything
