Hi David,
Thanks for to fix the display problem.( GH Bug layout display
I have a similar problem when I try to print a layout to a pdf file.
I attached the rhino (Quotatura_A00 - R6.3dm) e .gh (Bug print Layouts.gh) file to simulate the problem.
The pdf printed file (Quotatura_A00 - R6.pdf) , with the bug and the print screen (Quotatura print-screen.jpg) without the error.
Any view I try to print, the top view appears !
the same with view capture to clipboard and view capture to file.
I was actually asking you David since I wasn’t going to try and repeat the problem if you already tried That’s fine, it looks like this is happening in a very recent build so I’ll take a look.
Hi David and Steve,
to better describe the situation:
my customer has Rhino 5, so I was using a Rhino 5
(Version 5 SR14 64-bit (5.14.522.8390, 22/05/2017)
with Grasshopper Build 0.9.0076
I found the printing to .pdf problem, so I try the GH code with Rhino 6;
but I obtained the same printing error.
My customer is conscious to have to upgrade to Rhino 6 obviously!
