I want to print Layouts with the Filename at Top. When I choose vector output, I get the path two times in the Preview. When I print it, I get only one line. That’s OK.
But:
When I Print with Rhino PDF it take the second line.
When I Print with the local printer it takes the first line.
The first line is outside the printable area. So I get a paper without a complete path. Can I configure that?
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 7.9Gb)
Computer platform: DESKTOP
Primary display and OpenGL: Intel(R) HD Graphics 530 (Intel) Memory: 1GB, Driver date: 1-18-2017 (M-D-Y). OpenGL Ver: 4.4.0 - Build 21.20.16.4590
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.4 (primary GPU’s maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.4
Shading Language: 4.40 - Build 21.20.16.4590
Driver Date: 1-18-2017
Driver Version: 21.20.16.4590
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Users\simon.langhof\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\R+P AV-Tool (3bfacf54-8182-45fb-868b-341743e33bc8)\2.0.1.0\R+P_AVTool.rhp “R+P AV-Tool” 2.0.1.0
C:\Users\simon.langhof\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Users\simon.langhof\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\RKP_AV_SWARM\1.5.0.0\RKP_AV_Tools.rhp “RKP_AV_SWARM” 1.0.0.0
Thanks for that information.
The duplication and alignment of the file name was an issue that was fixed in Rhino 7.9. Could you please update your Rhino installation and try again?
Hi wim,
thanks for the quick answer. We have the current version in the Company. There the problem still remains.
I attach the SystemInfo from that PC. Do you have another idea?
Windows 10.0.17134 SR0.0 or greater (Physical RAM: 24Gb)
Primary display and OpenGL: Intel(R) HD Graphics 630 (Intel) Memory: 1GB, Driver date: 2-19-2020 (M-D-Y). OpenGL Ver: 4.6.0 - Build 26.20.100.7925
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 26.20.100.7925
Driver Date: 2-19-2020
Driver Version: 26.20.100.7925
C:\Users\Jens.Helfrecht\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\R+P AV-Tool (3bfacf54-8182-45fb-868b-341743e33bc8)\2.0.1.0\R+P_AVTool.rhp “R+P AV-Tool” 2.0.1.0
C:\Users\Jens.Helfrecht\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
When I use SaveAs to make a PDF I can’t see the path in the Preview. When I open the PDF it’s look good. It’s the same like I print it with Rhino PDF.
My problem ist the path at the printed paper. When I print it directly from Rhino the path isn’t complete. When I first print a PDF and print that on paper I can read the path complete. Use both printer the same “path-line”? Is the position of the path adjustable?
