Print as Rhino PDF scale 1:1 failed
Hello, I would like a PDF in the size 1500 x 3000 mm with objects that should be depicted 1:1.
Unfortunately, the PDF generated is far too small. Does anyone know the error?
Thanks for helping!
I’d create a layout to do this.
Thanks for your answer.
But unfortunately it doesn’t work.
Please post your Rhino file.
Hi, you can take a look to my post. Unfortunatelly we are still waiting they fix this issue.
Hi Martin.
Here is the file.
scale.3dm (68.4 KB)
You’re right. With Rhino 7 it work’s perfectly. :+1:
Mario,
it works fine for me with R8 if I configure a print layout.
cheers,
Benjamin
Hi Mario -
From your picture and your file, I see that you haven’t set the detail on the layout to be 1:1.
Printing the layout seems to work fine here:
I see that you are running 8.1. The stable version has been 8.2 for a while, and, if all goes well, 8.3 will be released later today. I’m running an internal version of 8.4, which will become public as a release candidate when SR 8.3 ships.
Printed from a the Layout and imported the PDF with no deviations.
It would be helpful to have Rhino version numbers as well.
