Press START BUTTON but nothing happend
wallacei2.gh (40.4 KB)
as my title said, after all the setting, when I press the start button, nothing happend.
I think it might be the problem of my machine, because I have tried the example file that provided by wallacei and it does not work either.
I have just run your file and it works just fine on my machine. There might be a problem with you machine.
wow, thank u so much! by the way, is there any way to fix this bug?
Without using your computer and see it first hand, I am afraid not. What is your Rhino version? please type down system info in the command line and provide the information here
Joe,
We’re you able to find a solution? I’m having this happen to me as well. Wallacei X is operating, its adjusting the number sliders, the model in Rhino is shifting, but the RunTime Solution/Generation, estimated time remaining, etc are all blank, and nothing is showing up in the Standard Deviation Graphs section, parallel coordinate plot, or objective space.
Definition was running fine yesterday. But this morning when I tried to run another set…nothing.
Using v2.7, Rhino 8,
There is a problem with you GH definition, make sure your objectives are changing as a result of a change in your parameters.
