I’ve got a building in Rhino where I have to check in each level if two points differ in height by 0.5mm. I usually select the point and look at the z-coordinate in Properties–>Details.
In lower levels there is no problem. For example I have z=24009.5 for the first point and z=24010 for the second point.
But as soon as the levels reach z = 100000, the decimals are not shown anymore. For example I get z = 133210 for both points. It seems that the coordinates are always represented by six digits.
Is there a way to augment the number of decimals/digits in the object description window? Or do you have another quick way to compare the z-coordinate of two points?
Thanks for you answers!
Enza
