Hi all.
I’ve been working with a lot of Stl’s lately, some for 3d printing, and some for conversion to subd/nurbs for manufacturing and have been finding a few weird issues converting meshes/stl’s.
The main thing is, if I try and convert a mesh to nurbs or quadremesh to subd, it will bring up a notification saying that it’s 20,000 surfaces or so and it may run out of memory or crash rhino. However, it never runs out of memory. It’ll sit there quietly and seem to do nothing either until it works or I give up and alt-ctrl-del out of it.
Some of the mesh’s I have reduced the mesh count to the minimum I can, though mesh count doesn’t seem to always be a factor. Sometimes it’ll convert 50,000 meshes no problems, and other times it’ll struggle with 20,000.
this is what my computer specs are.
And this is typical for usage (though I suspect this file isn’t working)
Now I have tested this on my laptop which has 12 cores and it seems to be better at converting the files.
So, is Rhino using ram to do this conversion, or are cores more important? Or is there some other issue that I might be having that I need to look into?
