Populating branches with null items
Hello, I have a question about trees.
I have lists of varying lengths that I need to join, but each branch need to be the same length as the longest branch, populated with null items. I was able to do this with a bunch of nodes but was just wondering if there’s a component that does this better?
Null.gh (20.2 KB)
Thanks for your help!
Wild guess no idea if it work but maybe cross-reference with nulls?
Or some of those components of that family
not behind computer, but mhave a look at ‘compare data’ or ‘match tree’
Without concrete solutions I was unable to produce any working results using your suggestions, but thanks for your help anyways!
double FlipMatrix
Tricky Dicky. You’re just full of surprises, aren’t you?
… How do you do the thing where component names are put in a round cornered box in posts?
You type <kbd>FlipMatrix</kbd>.
-w
Thank you, Wim.
How this works is beyond me but it works! Much appreciated, marked as solved.
