I usually import in Rhino 8 IGES files from Inventor2025 , sometimes I find some surfaces that are valid objects in Rhino but, if you look closely at them, they display incomplete isoparametric curve .
These type of surfaces give me problems in the next step of my workflow on CAM program.
If you look in the detail properties of these objects you’ll find that they have higher edge tolerance than the other surfaces.
I ask you if there is a command in Rhino that automatically detect them without having to visually scan the model.
attached you’ll find the iges file with export tolerance set at 0.001mm , internal modelling tolerance in Inventor should be 0.00001 mm and it’s hardcoded in the program (user can’t change it)
If so that is not a problem with the imported geometry. Instead it results from how Rhino displays surfaces. Rhino creates a “render mesh” from the surface and displays the render mesh. The render mesh is too coarse. To fix it go to Options > Mesh and change “Render mesh quaility presets” from “Jagged and faster” to “Smooth and slower”.
Added: Too coarse a render mesh can also cause gaps between surfaces to appear in the display. These gaps are in the display only, not in the surface geometry.
