The issue starts when I try to join a wiggly curve with the polyline. At that point, the fillets stop calculating properly, and the spacing of the elements (rack/bays) becomes inconsistent. Also, the connection between the polyline and the newly joined curve loses the fillet at that transition.
Does anyone know how I can fix this or approach it differently? I’d really appreciate the help.
(((I am not trying to add fillets to the control point curve but i want to join them together where only it is applied to the hard rigid polylines)))
Thank you for trying. The resulting breps or the half pipes you mentioned still don’t have the fillets between the polyline and the control point curves, which is the main issue.
In my setup, if you try drawing a polyline and then at its endpoint draw a multi-control-point wiggly curve and join them, you’ll see the problem. The fillet at that transition is missing, and it affects the overall result.
In your definition you have not internalized the curve so it is not possible to see the problem.
I tried different curves but the result is always correct.
