Why are these points being selected in different orders?
Just going through some basic tutorials and ran into this… haven’t found the cause, though.
Points were duplicated, so they’re exactly the same.
thanks
Did you select points one by one or all at the same time?
hmm, When you drag and select points you are not defining order of selected objects and leave space for interpretation and unexpected results.
But same list of points should produce same line
To be sure of the order of points: Reorder them.
Regards, Eef
Thanks Eef - I’d rather avoid that, as I’ll be using the same point set for multiple operation - also will be generating some sets out of Grasshopper.
then please upload your set, so we can have a look, and find maybe a cause and solution. regards Eef
Thanks @Volker_Rakow - the bottom one (curve) is still in the wrong order.
The two point containers do not contain the same lists of points.
