I have probably very easy problem with connection points with interpolate lines.
For the example i will use three simple circles.
So i have three curves with points on them and i want to connect points from one circle (1,2,3,4…) to another circle (1,2,3,4…) using interpolate curve.
My problems:
When i connenct points to interpolate curves i am getting this result
Of course when i change divide curve to graft i have the ruslt that i want.
But i want also to change order of the points (maybe twist them) to connect them in different ways. And here i run a problem, because when points are in graft mode they are 0,0,0,0.
So the question is. How can i change order of the points and then connect witn interpolate curve?points order.gh (11.2 KB)
