PointCloud > Remove loses intensity values
In Rhino 8.27, running PointCloud > Remove loses the scalar information in both parts of the result. Is this intentional?
I understand that adding points or another point cloud to a point cloud will not always work because points don’t have the intensity/scalar information. But splitting a point cloud into two parts could in theory maintain the scalars.
Thank you
Axel
Hi Axel -
I see that it doesn’t remove color, so probably not.
Could you post a pointcloud sample file with intensity/scalar information?
Hi Wim,
I shared a point cloud with RGB and intensity values with you privately. I tried to cut it down a bit, but noticed that when I select sub-objects (i.e. points) and delete them from the point cloud, the scalar values also disappear. This also appears to be a bug that is related.
Thank you
Axel
Hi @axa,
Thanks for reporting. I’ve logged a ticket.
– Dale
RH-92002 is fixed in Rhino 8 Service Release 29
Hi Dale, Brian.
I have tested PointCloud > Remove with 8.29 SRC. The operation no longer nukes the scalar/intensity information. Thank you for fixing this.
Selecting sub-objects (i.e. points) and deleting them from the PC still does remove the intensity information.
Best
Axel
Hi Axel -
Thanks → RH-92381 PointCloud: Subobject delete does not maintain intensity values
RH-92381 is fixed in Rhino 8 Service Release 30
Thank you @brian . I have tested with 8.30.26082.23001, 2026-03-23. That’s fixed now.
-Axel
Hi @brian ,
I’m afraid this issue also shows up in the new _SplitPointCloud command in R9 Beta
Thank you
--Axel
Hi @axa,
I have not been able to repeat what you’ve reported. Maybe we need a sample and instructions?
– Dale
Hi @dale
I stand corrected. I have not been able to reproduce this myself.
We are building up a pointcloud pre-processing pipeline based on CloudCompare, and are tinkering with many different options resulting in dozens of different E57 which we then feed to Rhino.
It seems that the 3 or 4 E57 files that I tried before reporting this had the scalar information wiped by our CC processing script.
Apologies for raising this false alarm.
--Axel
