Hi !
Does any one knows of a way /script to assign vertex color to a point cloud ?
Thank you
Shim
Hi !
Thank you
Shim
Hi, how do you plan to determine the colors for the pointcloud?
By X,Y and/or Z value, or are the points to be colored one by one, or by proximity to a mesh etc?
-J
Hi Holo,
I would prefer to do it by z values. but frankly I m not really sure how to assign any color at all. my intention is to export it to ply with the vertex color.
Thank you
As far as I know:
You would have to make a python script that reads all the original points into an array, then make a new array for all the z values and then make a new pointcloud that gets the colors assigned to replace the old.
Hi Shimon,
Below is a quick setup that might get you started:
import scriptcontext as sc
import Rhino
script by willemderks.com
quick n dirty setup to show how colors can be set to an existing pointcloud
color is set to a grey value relative to the lowest and highest point in the cloud
def pointcloud_zcolor():
ptcloud = rs.GetObject('select pointcloud',filter = rs.filter.pointcloud)
if not ptcloud : retun
#here we find the minimal and maximum Z value to be used to set the color
bbox = rs.BoundingBox(ptcloud)
zmin = bbox[0].Z
zmax = bbox[4].Z
#interval to easily calculate color later
interval = Rhino.Geometry.Interval(zmin,zmax)
#get rhinocommon pointcloud geometry object here
pcloud_geometry = rs.coercegeometry(ptcloud)
pass
#itterate through the points in the cloud and set the color based on the z value
for p in pcloud_geometry:
#color factor at point z
cfactor = interval.NormalizedParameterAt(p.Z)
color_gray_value = int(255*cfactor)
color = rs.coercecolor([color_gray_value,color_gray_value,color_gray_value])
p.Color = color
sc.doc.Objects.Replace(ptcloud,pcloud_geometry)
pointcloud_zcolor()
pcloud_height_grey.py (1.3 KB)
HTH
-Willem
Thank you !
I will give it a go
Another quick question for you experts…
Is it possible to export point cloud and a mesh objects in the same OBJ or PLY file?
Thanks again!
Sure, just script either the SaveAs
or Export
command using rs.Command
– Dale
