I have a pointcloud with colour attributes and I need to export to a CSV file so I can have the coordinates of each point and the RGB colour of each point.
Could anyone help me please?
Thanks,
Josh
Thanks,
Josh
I just checked in with the developers and there isnāt anything just like youāre looking for currently.
If you have a mesh with colors assigned to the mesh vertex points, that will export to the PLY file format with colors.
All the basic tools are there to export points with colors but no top level command for it that Iām aware of.
My guess is someone with good scripting skills could write a custom tool to do that.
Hi Josh,
Download and drop the attached button onto your Rhino workspace.
exportPtCloudToCSV.rui (5.7 KB)
djordje, thank you for this even though Iām not the original recipient
Iām looking to add the point normal data from the cloud to the export alsoā@djordje I assume itās just adding a variation on this:
for i in range(len(pts)):
if ptCloud.ContainsColors:
line = "%.3f,%.3f,%.3f, , %s,%s,%s\n" %(pts[i][0], pts[i][1], pts[i][2], colors[i].R, colors[i].G, colors[i].B)
else:
line = "%.3f,%.3f,%.3f\n" %(pts[i][0], pts[i][1], pts[i][2])
but for the normals into the code, right?
Hi Jonathan,
Yes you are right, it is one part of the editing.
Check the attached script below.
To run the script, in the Rhino application menu, click on: Tools -> PythonScript -> Run, then then find the downloaded exportPtCloudDataToCSV2.py file.
exportPtCloudDataToCSV2.py (3.1 KB)
Gotchaāthe rest of it being the update to the header lines, unless Iām missing something else?
This is standing in for the ply export for me right now as for some reason thatās broken for meā¦
Thanks!
Yes, the headers had to be updated too.
I havenāt understood you. What is broken?
Rhino just wonāt export to ply format, and crashes. The command log just shows:
Command: Export
Error writing file Z:\Dropbox_UnionNine\3.ClientWork\directory\testexport.ply
Error saving file Z:\Dropbox_UnionNine\3.ClientWork\directory\testexport.ply
Iāve already tried writing elsewhere (straight to C and Z:\ drive roots, outside of Dropbox to rule that out. Iāve also tried just opening and then exporting the point clouds and get the same result. Working on it with Brian @ McNeel in email ping-pong today.
That is the problem with Rhino PLY exporter, not with the upper script which exports points,normals coordinates and colors of point clouds to .csv file.
Correct, which is why Iām using the .csv file export youāve put together instead
As a corollary issue, Clementās script here doesnāt keep the colors or normals of the source cloud, so thatās my next challenge Iām working onāwith that and your CSV export I should be operational
Rhino 5 does not export PointClouds to ply format.
c.
That would explain it⦠would be awfully handy to have it do that
If you show @djordje a small example file containing the structure of such a ply file (ASCII), it will be possible for him to change his csv output script to do it. I guess all you need is the line prefix and the header.
Just curious, in which app you would like to import the ply file with points, colors and normals ?
c.
Iām looking to pull things into CloudCompareāyou can pull clouds in as CSV, but that requires setting it up each time to parse the file, whereas if itās a format that CloudCompare likes, then itās possible to automate with the command-line API with less fuss.
Then I can have a Python script call cloud compare with a subprocess call to do work on the clean cloud Iām exporting from Rhino, save that, and return to Rhino to open a resulting cleaned mesh-reconstruction so I can return to work on it.
Yay process automation X-)
Edit: even with your āslowā version, it still takes only ~5 minutes per comparison case to evaluate and return the normals-included version. Thatās not too shabby, but I can hear when my computer changes from full-threaded to non-full threaded in the fan speed
Thatās what my comment about Point3D was based on,starting to dig into the docsāyeah I saw the Point4d as well, but what we need is really a Point[N]D generalized object to hold additional attributes, or a way to match data between the data structures.
One thought of a āhackā way to do it was it could be multiple PointCloudsāsince my end product is getting composed back together outside of Rhino anyway. We could sample the cloud for actual locations to get cloud 1, then query the associated normals (and encode that resulting list of āpointsā of nX, nY, nZ data, and then do the same with color.
Then weād read the PointCloudLocation[x], PointCloudNormal[x] and PointCloudColor[x] values and put them into the csv or Ply format output file:
CloudCompareās ply header is:
ply
format ascii 1.0
comment Author: CloudCompare (TELECOM PARISTECH/EDF R&D)
obj_info Generated by CloudCompare!
element vertex 676336
property float x
property float y
property float z
property uchar red
property uchar green
property uchar blue
property float nx
property float ny
property float nz
property float scalar_curvature
end_header
And the subsequent lines are space-delimited, so itād be super easy to compose that formatā¦
⦠which you could then have Rhino āimportā as a new object I suppose X-)
As Clement mentioned, exporting cloud point data can be made in a way ply file requires.
But I do not know how to calculate the scalar_curvature variable your ply file requires. At least Rhino does not contain a native method to calculate it.
I added a ādefaultScalarCurvatureā variable on line 35, and assigned it a value ā0ā.
I am not sure whether or not this will work.
Maybe you should investigate if this scalar curvature variable could have some default value or not. If yes, then which one.
exportPtCloudDataToPLY.py (1.8 KB)
Scalars are added data in CloudCompare that is optionalāit looks like the core description for a Ply would just be the [x,y,z] point positions and point-count. Normals and color are optional tooāso those are values you list if your point cloud has them, otherwise you can leave them out. Hereās a Rhino .Ply header from when I did successfully get an export out:
ply
format ascii 1.0
comment File exported by Rhinoceros Version 5.0
element vertex 2698
property float x
property float y
property float z
property float nx
property float ny
property float nz
property uchar red
property uchar blue
element face 2562
property list uchar uint vertex_index
element material 1
property uchar ambient_red
property uchar ambient_green
property uchar ambient_blue
property uchar ambient_alpha
property uchar diffuse_red
property uchar diffuse_green
property uchar diffuse_blue
property uchar diffuse_alpha
property uchar emissive_red
property uchar emissive_green
property uchar emissive_blue
property uchar emissive_alpha
property uchar specular_red
property uchar specular_green
property uchar specular_blue
property uchar specular_alpha
property double shine
property double transparency
end_header
As you can see, thereās a lot of additional data there, and two whole additional element types with the faces of the geometry and a material indicated in addition to points. The subsequent lines of data look like:
40.000000 119.339996 0.000000 1.000000 0.000000 0.000000 0 0 0
For the set of points, which in the file are lines 36 to 2733, which would be 2698 elements. Then the lines look like this for the faces:
4 114 115 113 112
4 98 99 97 96
3 218 217 191
...jumping to last line, which is the material definition element...
0 0 0 0 0 0 0 0 0 0 0 0 255 255 255 0 0.000000 0.000000
Which to me indicates that they a) donāt have to use all the values necessarily, and b) the delimiter between elements is the ā/nā and the properties are just space-delimited, and setting ā0ā for a value you donāt have otherwise populated (like ambient/diffuse/emissive/shine/transparency on the āmaterialā) can be fine, if itās not going to otherwise cause problems in your downstream use of the data. In other words, setting a value for color or normal or even defining material isnāt important and may be counter productive if all you want is point locations, so itās just bloating the file size.
So if you have fewer properties, then on the subsequent lines of data you just have shorter linesāso a header with just [x,y,z] and [nX,nY,nZ] defined would have:
ply
format ascii 1.0
comment Author: Jonathans Revision of Djordjes script
obj_info Generated by Jonathans Revision of Djordjes script
element vertex [quantity of points]
property float x
property float y
property float z
property float nx
property float ny
property float nz
end_header
Then your lines would look like:
x1 y1 z1 nX1 nY1 nZ1
x2 y2 z2 nX2 nY2 nZ2
ā¦and so on for all the actual data.
Iām no Python syntax/parsing wizard, so it may take a bit but Iāll try to revise your script to include the right behavior, and then we have a new utility
