We’ve got some Point Cloud files which we need to manipulate, Is it possible to import a pcg file into Rhino.
Hi Martin, Rhino does not yet see PCG files, but i would appreciate if this changes soon as it`s becoming the standard. Meanwhile you might want to try to import your PCL file into CloudCompare, then export from there into a readable ASCII format which Rhino can import as comma seperated file (eg. txt format)
c.
Thanks for the suggestion on importing this format. I’ve filed the request as RH-20645. This report is not publicly visible at this time.
