Point Bevel
Can Rhino7 Bevel a point?
Do you mean like this?
(Note that the pyramid being bevelled gets truncated at the point where the bevels touch, so if you want to come to a sharp point you have to add a small pyramid to the top)
Jeremy
Hi, I ment to take a box and when you bevel the 8 point of the box you get 8 triangles like it works in modo, can it be done in rhino?
Thank You
Like this?
There is no native command to do this in a single step if that is what you are asking (I’m not familiar with Modo), but it is easy to construct and could be scripted.
Regards
Jeremy
Thank You what I also ment & didn’t write was to do this as a subD tool for points in a subD mesh.
Hi @emquies, this feature is not in Rhino but it has been requested earlier here: Add SubD Chamfer Vertex for Rhino7?
I registered your request too.
Thank you
I think Lunchbox in GH could give you, in some cases, similar effects and control.
It can be done with Weaverbird.
20_12_28_weaverbird_bevel_edges_vertices.gh (14.9 KB)
Thank you , I wanted to use the point bevel inside a work flow for manipulating subD.
My big wish is that the rhino gumball & the subD selection tools(Filters) would be similar to Modo
With these two (Gumball & smart selection of Points\polygons\edges )you can easily manipulate a subD object
