Can someone please guide me the setting from where I can change the gh sdk version when building a gh plugin from visual studio?
Lower rhino 6 sr versions are failing to run the exported plugin for the obvious use of latest sdk version. Any external link shall be helpful too.
Thanks!
Hi @joy.architect,
Just in case you still waiting for an answer, check this out: GH Component was build against a newer minor version
I had a similar (or the same) problem a while back and I remember I solved it from here.
I’m actually about to have to do the same again, so let me know if you have any issues. Even though I did it once, I might struggle with it, since the last time I did it was ages ago (actually 1,5 years, but that converts to ages in Corona time) so maybe we can help each other.
