Plug-in not installed error message
After launching Rhino I’m getting this error message
3 times in regard to RhinoDLR_Python plug-in
1 time in regard to MaideRhinoPlugin plug-in (Maide Connect has been uninstalled)
How to get rid of this messages?
I should have mentioned that I tried removing and reinstalling Rhino (both just deleting from Applications and using AppZapper, which helps to remove related files) but it didn’t help.
From AboutRhinoceros:
Software information
  Software versions
    Rhinoceros version:  5.0 Wenatchee 2014-10-14 (5A552)
    IronPython version:  5.1.2014.1006
    Language:  en (MacOS default)
    OS X version:  Version 10.10 (Build 14A389)
  Plug-ins
    /Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
  Third party kernel extensions
    com.rim.driver.BlackBerryUSBDriverInt (0.0.74)
    com.Logitech.Control Center.HID Driver (3.6.0)
    com.Logitech.Unifying.HID Driver (1.2.0)
    org.virtualbox.kext.VBoxDrv (3.0.6)
    org.virtualbox.kext.VBoxUSB (3.0.6)
Hardware information
  Computer hardware
    Hardware model:  MacBookPro4,1
    Processor:  Intel Core2 Duo CPU     T9300  @ 2.50GHz
    Memory:  4 GB
    Architecture:  Intel 64 bit
  Video hardware
    Graphics:  GeForce 8600M GT     512 MB
    Memory:  512 MB
    Screen size:  1440 x 900
    Displays:  Color LCD
  USB devices
    Apple Inc.: Built-in iSight
    Apple Inc.: Bluetooth USB Host Controller
    Logitech: USB Receiver
    Apple, Inc.: Apple Internal Keyboard / Trackpad
    Apple Computer, Inc.: IR Receiver
  Bluetooth devices
    None
OpenGL information
  OpenGL software
    OpenGL version:  2.1 NVIDIA-10.0.19 310.90.10.05b12
    Render version:  2.1
    Shading language:  1.20
    Maximum texture size:  8192 x 8192
    Z-buffer depth:  24 bits
    Maximum viewport size:  8192 x 8192
  Implementation settings
    Use texture compression:  No
  Appearance settings
    Antialiasing:  2x
    Mip map filtering:  None
    Anisotropic filtering:  None
Plug-ins are installed in
~/Library/Application Support/McNeel/Rhinoceros/MacPlugIns
directory. If you delete the subdirectories, everything should work again.
I can’t find both McNeel and Rhinoceros folder under ~/Library/Application Support/ or anywhere else.
Is it possible it is installed differently under Yosemite?
you’re (i assume) not in the ~User library…
the user library is hidden by default since 10.7 iirc…
one way to get to it is:
• click the finder icon in the dock
• at the top of the screen, click the ‘Go’ menu
• press&hold the option key
• notice the item ‘Library’ appears under the go menu.
that’s your user library.
That’s it, thank you!
I seldom use Mac OS and don’t know such secrets… In fact I thought the idea was not to make UI secretes but that was long time ago.
well, i think the idea was apple trying to encourage developers to keep the users out of the folder structures (i.e.- anything associated with an application should be accessible from within the application itself)… in many instances, i’ve seen this working out… it’s not so much keeping UI secrets as it is simplifying the user experience by not expecting them to navigate thousands of folders/paths…
anyway, if you want to unhide the user library, do this:
• in finder, go to your user folder Macintosh HD-> Users-> your user name (it’s the folder with the house icon)
• View menu -> Show View Options (cmmd-J)
• tick the box ‘show library folder’
