I used a ‘clipper’ to make an offset curve inside the panel.
The plane setting was resolved using the ‘Deconstruct Rectangle’.
However, when I zoomed in and looked closely, I found an excitation on the panel plane.
To solve this problem, I used ‘offset on surface’ to solve it, but this time I’m not able to delete the intersection line inside.
Question1) How do I fix the plane setting when I use the ‘clipper’?
Question2)How can I trim an internal intersection if I use ‘offset on surface’?
panel_question1.3dm (34.4 KB)
panel question1.gh (11.7 KB)
