Please help FlowAlongSrf
I have tried the FlowAlongSrf command several times, but I haven’t been able to make it work. Could you please guide me through the process?
kolon.3dm (2.3 MB)
Are you looking for this kind of tutorial?
Thank you so much. The pattern needs to continue seamlessly across the entire column, following each other continuously, similar to the attached image.
Use the “Merge” tool with the “Round” option off to combine all the surfaces into a single surface. Then unroll the surface into a flat copy on the ground plane and place your pattern inside. That should let you place the pattern on your column.
If necessary, you can rebuild the flattened plane to include at least 5 control points along the vertical direction, in order to be able to control how the pattern flows over the column. If you see some distortion of the pattern over the column, simply move the control points of the flattened plane up or down accordingly. But make sure that you use History recording before the “FlowAlongSrf” command.
P.S. By the way, looks like the screen-shot you posted shows some fake AI stuff, because the pattern looks like a parallel projection instead of a proper 360-degree flow along the column.
FlowAlongSrf isn’t really how you would create that, or at least you’re not understanding how FlowAlongSrf works properly to even begin to create this with it.
this looks more like a texture that is projected in parallel …
(a parallel projected texture viewed with perspective camera)
…see those strange artefacts (violett).
Also if the green distances should be (nearly) the same - you need some magic to increase the number of cells for the much larger diameter at top.
how do you want to handle this in 3d ? - and not only nice from one camera position.
kind regards - tom
