Hi, in order to create a seamless pattern flow along surface, I drew the planar surface like in this image:
However it still creates a seam where they connect:
Does anyone know how I could create a seamless pattern?
The pattern needs to overlap the edges of the base surface to wrap around like that, you just need to adjust the base surface a bit.
It’s like you’re not quite getting how FlowAlongSrf works, it’s like UV texture mapping, geometry is copied according to the parameterization of the untrimmed base surface to the untrimmed target surface.
So I need to adjust the base surface which is the surface of the pattern, right? And it has to be a rectangle.
Yes, and the trimming you did to it just doesn’t matter, all surfaces are rectangles.
To get the pattern to overlap the seam like you want, you need the pattern to overhang the base surface just the same…well more-or-less the same, I dunno, extrapolating beyond the edges of the input can get wonky. It may be more reliable to simply have the pattern trimmed off.
Now, for some reason it doesn’t connect at the seam only at the edge points of the pattern
The middle point it connects fine
Project file: Unique Download Link | WeTransfer
your file does not provide the target surface.
please post a .3dm file with
base surface
target surface (missing)
only the columns of pattern at left / right (green in my screenshot)
and save small → this should allow an upload to this forum without wetransfer.
it s impossible to help, as long it s unclear which base and which target surface you used.
best - tom
The target surface is under the baked result of the flow along surface on the right in your screenshot, if you delete it the brep target surface is under it but I will post it again the way you asked for it, thank you.
Here it is:
01.3dm (393.3 KB)
is invisible to to the bad custom color that conflicts with standard rhino viewport background color.
flowAlongSrf will check the underlaying nurbs surfaces.
one element
possible approaches to improve the result:
use _ shrinkTrimmedSrfToEdge to get tighter surfaces before you flow them
do not flow any objects “over the surface seam”,
flow the first half of the objects
use _srfSeam (target surface) and then do a second flowAlongSrf
maybe the best approach: only flow one column of objects - as your target surface is a revolve, than _arrayPolar this row of objects
you might combine this by having a smaller stripe as base and target surface / revolve only for a few degrees. this will reduce the complexity of the flow operation.
build the inital surfaces with untrimmed surfaces only (_srfPt)
make sure also the triangular surfaces are untrimmed / one edge is collapsed. (srfPt click last point twice)
you have one 5-sided surface - build it with 2 4-sided Surfaces, after flowing you will have a minimal kink here - knowbody will see it.
with this setup (untrimmed surfaces only) you can use “presever structure” option of flowAlongSrf.
combine arrayPolar approach with preserve Structure.
rebuild the 5-sided Surfaces in one column , array polar the result.
hope this helps - kind regards -tom
