Please add angle degrees when rotating as reference to estimate and then type final degree
Ok thought I’m an idiot but as reference in the last post showed ~330 degrees, when typing “<330” to constrain to this degree, this would constrain to 240 degrees. Maybe this could be fixed.
Hi Hannes - here, if I use <330 in Rotate
, it snaps correctly as far as I can see. Maybe I am missing what you are trying to do.
I wish Rhino reported translation info in real time. Interactivity and UI are Rhino’s strongest features.
i believe both angles can be displayed with the cursor tool tips, the relative and the absolute
@pascal Status bar would say 330 degree, but when I type 330 degrees, it’s snapping to 240 degrees…
Finally established this little fucker
Kaleidoscopic Layer - have to find some gallery guys with enough money to CNC mill it from alu
