I was hoping that someone could help me with a file I am working on. It’s based on a video tutorial and I am stuck with the PlanarSrf command. I have a 100 closed curves arrayed around a circle but only 3 will work with the Planarsrf command.
Well, I created the geometry using the loft command and then used the extractwireframe command. The odd thing is that some curves are working with the PlanarSrf command the others don’t even though they were created in the same way. Also, it’s the exact same process as in the video where the person had no problem with the command.
Hi Deniel - that may work, sometimes in special cases but it is not a reliable way to get planar curves - use the Section command for that, I would say.
The problem is that I don’t think I could get the same geometry with the section tool (At least as far as I know). If you turn on the red layer you can see that it is really complex. Basically a fairly regular and close frame extracted from an object.
Is there a way to make these curves planar and make them work with the PlanarSrf command?
